- Snake Oil... Why do you want to try it?
- Hank85713ExplorerI have bought it, but have not done an oil change yet. I have used rev x and it does seem to help, diesel power just did a review on archoil 9100 and found it does work and helps to loosen up the injectors. They have a printout with actual before and after injector checks. In issue about a month or so ago
- JIMNLINExplorer IIIThere are a lot of those type of products on the market and when I want to try a product I simply buy it and use it. That way I know if it works or doesn't work to my expectations.
Most folks yell snake oil have never tried the product and know nothing about it .... but have a opinion. - ACZLExplorerStuff works! Highly recommend it. How many snake oils come with a money back guarantee?
- darsbenExplorer II
All snake oils come with a money back guaranty. The salesmen know most people will not ask for their money back once they use a product as it is to much bother - 45RicochetExplorerThat blue one sounds interesting, -65 pour point.
- mowermechExplorerI am highly suspicious of any company that puts a pdf file on the internet containing the MSDS for their product that is NOT FILLED IN, and gives NO information abut the ingredients.
do a google search for hot shot's secret msds and see what you find. Maybe you will find one that has some information. - DirtyOilExplorerfrom their website.... first page of the MSDS, looks like they have the proper documentation as per MSDS guidelines:
Number: 00312121
MATERIAL SAFETY DATA SHEET
1. CHEMICAL PRODUCT AND COMPANY IDENTIFICATION
Product Identification
Product Name: Diesel Extreme Clean and Boost
Product Number: 66000
Synonyms: Diesel fuel additive
CAS Number: Blend
Company Identification
Manufactured for:
Lubrication Specialties, Inc.
255 Neal Ave.
Mt. Gilead, Ohio 43338
1-800-341-6516 (For product information)
1-800-424-9300 (For emergencies)
1-800-424-9300 or 1-703-527-3887 (CHEMTREC)
Diesel Extreme is approved by the EPA under USA blend.
2. COMPOSITION / INFORMATION ON INGREDIENTS
COMPONENT LISTING:
Chemical Name
Amount
CAS Number
2 - ETHYLHEXLY NITRATE
30.0 - 60.0%
27247-96-7
DISTILLATES, PETROLEUM, HYDROTREATED LIGHT
30.0 – 60.0%
64742-47-8
BUTAN - 1 - 01
3 – 5%
1-36-3
SOLVENT NAPHTHA, PETROLEUM, HEAVY AROM.
3.0 – 6.0%
64742-94-5
SUBSTITUTED PHENOL
< 2.0%
Proprietary
1, 2, 4 - TRIMETHYLBENZENE
< 1.0%
95-63-6
NAPHTHALENE
< 1.0%
91-20-3
1, 3 , 5 - TRIMETHYLBENZENE
< 0.2%
108-67-8
(See Section 8 for exposure guidelines)
(See Section 15 for regulatory information)
Ethylhexly Nitrate = Cetane booster
Trmethylbenzene = simply... thinner
Substitued phenol = detergent (also used in anesthesia)
Naphthalene = solvent - agesilausExplorer IIIAs a chemist let me point out that Napthalene is a white solid not a solvent. It's one of two chemicals that are used to make moth balls. Paradichlorbenzene being the other. The Ethylhexylnitrate seems to be the main active ingredient along with the petroleum distillate (mineral spirits or kerosine).
About Travel Trailer Group
44,029 PostsLatest Activity: Jan 19, 2025
