โDec-02-2013 02:06 PM
โDec-08-2013 03:53 PM
โDec-08-2013 06:44 AM
โDec-07-2013 05:18 PM
โDec-07-2013 04:52 PM
devildog1971 wrote:
If your fridge is in your slide you need to put that bubble level in the fridge especially I found out the hard way if your slide ever creeps in a little the fridge will be way out of level because the last little bit the slide goes out it pushes the top more than bottom that is so water will run out cost me a fridge rebuild luckily I found a shop that replaces the back side. the factory put a brake on my slide and told me all slides especially ones with fridge in slide and the slide is electric (12 volt) they need a brake installed it also stops a slide from creeping out when closed I think the refers have ammonia in them but if bouncing will help with cholesterol I will try bouncing a lot
โDec-06-2013 08:32 PM
โDec-06-2013 08:13 AM
RichieC wrote:
Somewhere, probably on rv.net, I read that taking the refrigerator out and turning it upside down can restore it to working order.
Not sure that this would ever be done in a campsite, but is there any truth to it?
โDec-05-2013 04:57 PM
camperpaul wrote:RichieC wrote:
-- snip -- I read that taking the refrigerator out and turning it upside down can restore it to working order.
--snip -- is there any truth to it?
It's a temporary band-aid fix and doesn't always work.
โDec-03-2013 05:35 PM
โDec-03-2013 05:26 PM
โDec-03-2013 05:07 PM
โDec-03-2013 03:45 PM
RichieC wrote:Old-Biscuit wrote:
Fridge damage from operating 'off level' is accumulative...kinda like clogging arteries. You are not aware of the damage until it's too late.
"Time duration" has to be part of the equation.
5-minutes off level won't damage it. What about 5-hours? Or 24-hours?
Does the travel vibration tend to redistribute the cholesterol?
โDec-03-2013 03:24 PM
Super_Dave wrote:portscanner wrote:
If DW doesnt complain, you got it right
Are you speaking in general or specifically about the camper being level? This might put me in a no win situation.
โDec-03-2013 11:32 AM
โDec-03-2013 10:50 AM
