Nov-30-2015 04:02 PM
Dec-02-2015 08:58 PM
EQUALIZER wrote:
The only negative report I’ve heard about going bigger is a stiffer ride, and even this is when the “proper sized” hitch is a 6K and they go with the 14K.
Dec-02-2015 08:40 PM
Dec-02-2015 07:35 PM
I currently have an equalizer hitch and my friend is considering a purchase. Both of our trucks and campers are almost the exact same size and we both have the same questions regarding exactly which size hitch to get. We used the form on your website and it typically recommends the 10k hitch but depending on how much tongue weight or cargo weight we estimate then it sometimes starts to recommend the 12k hitch. When I bought my hitch I just went with the idea that it is better to get the larger hitch and not worry about it so I bought a 12k hitch. My friend is having doubts if this is the best logic to use and if he should get the 10k to make sure it properly fits his camper.
I started an RV.net forum topic on this subject to get opinions and the answers I am getting inconsistent.
In my opinion, how the hitch is set up is what determines the amount of weight being transferred from the trailer to the tow vehicle and you could buy the 14k hitch to tow a pop-up and it would be fine as long as it is setup properly. Others seem to them that this would cause a horrible ride or possibly cause damage to the trailer because too much weight is being distributed.
What is Equalizer's professional opinion on this?
I’m glad you contacted us as there is a lot of confusion and misinformation about this topic! First let me go ahead and dispel the biggest myth about getting a larger size hitch: a bigger sized hitch will NOT damage or bend your trailer tongue. I’m not sure how this rumor was started, but these frames are constructed to carry these humongous trailers and it will take much more than a hundred pound hitch to damage one. Especially since the Equalizer attaches to brackets that are attached to the frame and not the frame itself. So that is not an issue at all.:
As far as getting a bigger hitch, if there is any possibility of going over the GVWR or tongue weight ratings of a certain hitch, I would get the next size up. It is much better to have a bigger hitch than be caught down the line towing more than the hitch can handle. The only negative report I’ve heard about going bigger is a stiffer ride, and even this is when the “proper sized” hitch is a 6K and they go with the 14K. That being said, all Equalizers will be a bit stiff when they are new. This is due to the new steel-on-steel friction surfaces and the sockets being torqued a bit higher than usual. However, as you start to tow with the hitch will begin to wear together and break in and any stiffness will vanish after a couple of trips.
Anyway, long story short, you and your friend should have no issue going with the 12K as long as it is set up correctly. I would try to have your tongue weight ~10% of the trailer weight for the best ride, but even that can be compensated for with hitch adjustments. I hope this helps shed some light on the situation, but feel free to ask any questions you might still have.
Dec-02-2015 11:23 AM
Huntindog wrote:I fully agree.
I think that it's a pretty safe bet that EQUALIZER employed some engineers when designing their products.... And they designed it with different sizes.
I also think that it's a pretty safe bet that those calling EQUALIZER for advice are not speaking with any engineers... But just someone with a customer service title paid to answer the phones and stroke the callers egos. (that is what customer service is about, making the customer feel good.) I believe that EQUALIZER employs some who are very good at their customer service job.
I also believe that they employed some who were very good at their engineering job..
Dec-02-2015 10:32 AM
Dec-02-2015 09:43 AM
LarryJM wrote:Larry, perhaps you missed the previous post by the OP in which he speculated:dodge guy wrote:Your above ridiculous scenario just proves the point I was trying to make that some posts like yours are sometimes not even worth what we paid for them .... Nowhere did anyone, Equal-i-zer nor those that spoke with the folks at Equal-zer even hint at what you are now suggesting to be O.K.
Well go ahead and use a 1400lb hitch on a TT with a lightweight frame and 600lbs of tongue weight then see what happens when you go over a dip in the road or in/out a steep driveway entrance! let us know how that works out. the WD hitch bars are spring bars and need to flex to work properly. this is fact and not opinion! So yes they need to be sized to the trailer you have now and not one you may own 5 years down the road, besides you can replace the bars when you buy a new trailer!
mfoster711 wrote:IMO, the post by dodge guy is an entirely appropriate response to the OP's belief that it would be okay to use either a 6k hitch or a 14k hitch on a pop-up.
In my opinion, the amount of weight being distributed from the trailer to the TV is determined by how the hitch is setup, not by the weight rating of the hitch. In other words, I could use a 14k hitch or 6k hitch on a popup and as long as both are properly setup then the amount of weight being distributed would be the same.
In this example, if we were using an Eaz-lift WD hitch, the number of washers used at the shank and the number of links used on the bars would probably be very different between the 14k hitch and 6k hitch when used with a pop-up. But, if setup properly, both should still work the same. Of course, it is very possible you might have difficulties setting up the 14k properly for a pop-up because the springs are too stiff.
Dec-02-2015 09:42 AM
I don`t know why so many find this hard to process! like I said this is fact and not opinion. many of us here have 10`s of thousands of miles towing. I would trust the Expert that has towed their TT 4-5K miles a year vs. someone who is just trying to sell them a product!
I guess you can believe that what you post is factual, but to say it's fact and not an opinion is IMO the height of arrogrance when faced with counter information to your alleged FACTS and what must be considered more expert and factual from like the maker and designer of the product in question. Again I would only suggest those reading this is if they really consider someone to be an EXPERT who has towed their trailer 4 to 5K a year ... IMO that would make a whole lot of us here "EXPERTS" which often disagree with each other on I guess what you would call THE FACTS.
My fact to add I guess is that as I previously stated I have now been using an Equal-i-zer system one size larger than needed for close to 9 years and over 20K miles with no adverse ride quality issues and no damage to my 7500GVWR trailer frame. I have little doubt that I could have also used the 1.4/14K system with the same results, but I choose not to spend the extra for that system knowing I could never have those TWs because of my vehicle and it's receiver inherent limitations.
Larry
Larry
Dec-02-2015 09:30 AM
Dec-02-2015 04:33 AM
Dec-02-2015 03:48 AM
Dec-02-2015 03:27 AM
Dec-01-2015 11:05 PM
Deep Trax wrote:
I understand what you are saying and see why you think there may have been a misunderstanding. I don't think so, but anything is possible.
Rather than disagree or try to explain things further, I would encourage the OP's friend to contact EQ directly and allow them to help make the best choice for their application. I found them to be very knowledgeable and helpful. I'm very comfortable that they helped me make the wisest choice for my situation.
If I was choosing strictly for todays TT & TV, I would own a 12K model hitch. Since I also wanted to consider my hitch needs should I go to heavier trailer later down the road, I opted for the 14K model. To each their own.
I'd also recommend that people use caution when listening to what an RV dealer tells them. I bought from a dealer claining to be the "second largest RV dealer in the world" (McGeorge's Rolling Hlls RV) and they put the wrong components on my truck & trailer not once but twice.Ron Gratz wrote:Deep Trax wrote:I believe there is a misunderstanding here.
The E4 hitch is designed to work properly as long as your TT has tongue wt greater than or equal to 10% of the rated tongue wt of the hitch. If you buy the 1,200 / 12,000 lb hitch, your TT must have at least 120 lbs of tongue wt for the hitch to function properly.
The WARNING section of the installation manual states:
"Always tow with a minimum tongue weight of 10% of gross trailer weight."
The yaw-resisting torque (sway control) generated by the Equal-I-zer WDH is a function of the amount of load transfer.
The amount of load transfer is determined by how the WDH is set up, and usually is a function of tongue weight.
I doubt that having a 1200# TW rated hitch means the sway control will operate properly with a 120# TW -- especially if the trailer weighs 12,000#.
I believe the 10% minimum tongue weight guideline refers to the actual loaded trailer weight rather than the rated tongue weight of the hitch.
Ron
Dec-01-2015 07:53 PM
Dec-01-2015 06:06 PM
Dec-01-2015 05:52 PM
Ron
