TN_Sportsman's avatar
TN_Sportsman
Jackknifed trailer into TC Jack!!
:oWell as I was preparing for our maiden voyage with my "new" TC, I noticed that the extended hitch for towing my 18' G3 was not quite extended enough. I did some maneuvering in the driveway, and determined that I would need to get a longer hitch. But since I was all loaded up, campsite awaiting, etc., I figured I would be ok as long as I stayed away from really tight turns. Well that was true until the last day when I loaded up, and got going down a 2 lane highway and had to make a U-turn:S. Yup, it was just enough that the boat got into the rear jack and pulled the lag bolts away from the frame. I was so p!$$ed at myself because I knew better!!:M The damage is shown in the pics below.
Upon the removal of the jack and brackets, I believe I can fix this. It looks like the corner frame is possibly a 1x2 or 2x2? The wood appeared to still be pretty solid, but it did split somewhat when the lag bolts pulled loose. It did seem to go back together pretty well. I'm thinking that I can get one of those epoxy wood repair kits and inject it into the cracks, lag bolt holes, and fill in the void areas. I think I could get some slightly longer lag bolts, re-arrange the hole patterns for the top (larger) bracket. The lower (smaller) bracket does not have much left to grab to. It does not appear to be the load bearing bracket, so I think I could rebuild the void area with the wood epoxy, and weld a small triangle piece to the bottom (where it would "cup" the bottom corner), and put in longer lag bolts.
This has made me sick, especially because I knew better. Any thoughts/suggestions to my idea?
