pitch's avatar
pitch
Apr 17, 2019
Larger tires
Has anyone successfully upsized the 13" tires on a Jayco 23b to 14's? My research (such as it is) shows the 14's as needing an 1½ more space each. This would leave ¾ to 1" clearance between them. Is that enough?
Plenty of room elsewhere.
  • All I could afford wrote:
    If you have 175/80/13 now, consider upgrading to 185/80/13 in a load range D as I did. I gained a little height and about 250 pounds per tire of capacity
    That is what I did. They are Bias as opposed to radial. We shall see how they do.
  • If you have 175/80/13 now, consider upgrading to 185/80/13 in a load range D as I did. I gained a little height and about 250 pounds per tire of capacity
  • I believe (e Trailer) the recommended is 4 inches but Dexter says a minimum of 1" will work.
