โOct-20-2019 08:18 PM
โOct-21-2019 07:50 PM
โOct-21-2019 05:10 PM
K_and_I wrote:Sounds like a plan. Based on 11 trips I've made to Alaska (9 full summers up there) that's about the last place I'd expect you to have that sort of a problem. Alaskans I've met (and there has been a bunch of them) would be more apt to go out of their way to help you than steal anything. The guy I knew who lost his generator was on the desert in -----------------wait for it---2manytoyz wrote:
Though I have a different brand of generator, I lock mine in place when in use.
I'm using a Masterlock Python model. I drilled a hole through the frame plate since it was all too easy to remove on bolt to slip the lock off the handle.
Affiliate link here: https://amzn.to/2BrbHsP
I use 2 of these Masterlock Pythons, wrapping around the generator on both sides, and going through a hole drilled in the rack it sits on. I found that Home Depot has these in 8' for a couple bucks more than Amazons 6' length, which was not long enough to go around my generator and rack.
Home Depot
Yes, a determined thief can go through these, but there are 2, and will take some time. We did a 10 week trip to Alaska, and the gennie is still sitting on its rack.
โOct-21-2019 04:05 PM
โOct-21-2019 12:58 PM
โOct-21-2019 12:24 PM
โOct-21-2019 08:39 AM
โOct-21-2019 08:35 AM
โOct-21-2019 07:54 AM
โOct-21-2019 07:20 AM
โOct-21-2019 07:11 AM
โOct-21-2019 07:00 AM
