camp-n-family's avatar
Oct 04, 2019
Lowering TV tire pressures
For those of you with diesel HD trucks that lower their tire pressures when not towing, what do you set them to?
My Ram calls for 60psi front and 80 in the rear. As most know, this gives a pretty harsh ride. I finally found someone to reprogram my TPMS to lower the thresholds so I can now lower them more than 8psi before triggering the dreaded dash light.
I’ve currently set 55 front and 60 rear which is a much smoother ride but I’m wondering about the effects. Tire wear? Controllability?
I have 60k kms (42mi) on my Toyo’s and they are at about 50% wear and evenly worn. I can already feel that the traction in the wet is much better as it will be in snow too.
Will lowering the fronts cause steering issues? Since all the weight is up front with the diesel should I lower them at all? In theory, with all the weight up front and little in the rear I should be able to lower the rears to less than the fronts. Any problem with that?
