CharlesinGA
Nov 22, 2020Explorer
Marker lights on a Thor I have sitting in my shop had #194 lamps in it. I ended up using bulbs from SuperbrightLED to replace them.
https://www.superbrightleds.com/moreinfo/boat-miniature-wedge-bulbs/194-led-boat-and-rv-light-bulb-5-led-miniature-wedge-retrofit-30-lumens/2485/874/#/attributes/10837
![](https://d114hh0cykhyb0.cloudfront.net/timthumb.php?h=480&q=90&src=https://d114hh0cykhyb0.cloudfront.net/images/uploads/194-nw5.jpg&w=585&zc=2)
They worked well for the purpose. I normally use LED's from M4Products, in fact that is all I use, but I could not find something I liked for the clearance lights and ended up with the SuperbrightLED ones. I tested them by jumpering the power to running light contacts ont he trailer 7 pin connector using a turn signal flasher and let them flash for a couple of days to prove out that they all worked. Each bulb in the link uses 5 LEDs so the light scatter under the lens is good.
Charles
Charles
