Perrysburg_Dodg's avatar
May 24, 2013
Michelin Tires
OK I have them on my truck (bought last year) and was sold on them because they gave me $480 off do to the sidewall cracking on my BF Goodrich tires. They (Discount Tire) told me this would not be an issue with the Michelin"s.
Well the DD's Volvo had to go into the body shop and while it was in there I decided to pull the headlamps and replace the seals and clean the reflectors. After getting permission from the shop manager I was removing the lamp and the painter comes to me and asks if I own this car? I said well yes but it's my daughters car. He tells me "well I wouldn't let me daughter drive on those tires"! So I look at them and you can almost see the sidewall cords through the cracks!!!
The date on the tires were 2009 and the car was bought (used) on 2-2010 and that was when the tires were put on the car. Discount Tire said the rears had 6/32 and the front had 5/32 of tread left. New they had 11/32 and Michelin said they would give me 35% credit towards a new set.
There reasoning is because at 3/32 your tires are to be replaced. OK then if new they have 11/32 but you loss 3/32 of tread wear then you really only get 8/32 of useable tread, seams like a rip off to me. I have never owned import tires before but I might just have to look at them the next time I need tires.
Don
