MnStar
Oct 16, 2016Explorer
No 12 volt in 2003 Jayco Kiwi
My wife and I just bought this, and I think it's going to be a perfect camper for us. I've been going through the whole thing fixing minor issues.
The battery that came with it was toast. I bought a new one, and while hooking it up I noticed quite a spark while touching the hot to the post with the negative hooked up. I didn't think too much of it, but when I finally did attached the hot there was no spark at all. Sure enough, no 12 volt power.
I checked all the fuses in the panel by the converter, but they were all good. I think those are for 120 volts anyway, right? There is a 30 amp fuse coming off the negative side of the battery, which I though was unusual. In the past, any fuse has been on the hot side of the battery, not the ground. I did check that fuse and it looks good but I am going to get a replacement and try it anyway.
Any other ideas?
TIA
Any other ideas?
TIA
