โMar-22-2015 06:17 AM
โApr-13-2015 08:45 PM
โMar-28-2015 08:28 AM
โMar-28-2015 08:20 AM
โMar-28-2015 08:15 AM
โMar-28-2015 07:05 AM
โMar-28-2015 03:53 AM
โMar-27-2015 03:11 PM
โMar-27-2015 03:07 PM
โMar-27-2015 10:36 AM
โMar-27-2015 08:17 AM
โMar-27-2015 04:50 AM
rfgaugush wrote:
I picked up my new Outfitter Caribou Lite 6.5 on 17 March and then spent a week with with it in New Mexico before returning home.
My options:
extended cabover - N-S bed is 80" x 80"
cassette toilet
furnace
3.8 cu ft Dometic 2 way refrigerator
hot water heater
external shower
100 watt solar panel
2 6v batteries
Torklift frame mounts
Torklift steps
โMar-26-2015 08:17 AM
โMar-26-2015 06:58 AM
sleepywheel wrote:
Going to have to keep an eye on this thread......
Sold my Palomino Bronco 1251 a couple of years ago because my wife and I had both banged our heads on the fold down rear wall when the top was lowered. I'm in the market now for another pop-up camper and have found an 2006 Outfitter Caribou that sounds promising. From the sounds of it, the interior needs freshening up due to faded cupboard doors but everything else seems fine.
One thing that I really want is a hot water heater and an outside shower. Since this one doesn't have either, how much work is it to put in? Is there usually a spot where they go where I can just cut the holes in the side of the camper to install? I'm not worried about the plumbing side of things, it's if there is enough room to install a water heater. I don't know if the inside cabinets from the factory are the same whether or not a water heater is oem.
Thoughts?
โMar-25-2015 10:54 PM
silversand wrote:
Sleepy:
We don't have outside shower nor hot water heater in our Caribou.
I'm not sure where the heater would be installed; I'm guessing: under the kitchen counter?
I think you need to find the aluminum frame (hidden under the fiberglass laminated sandwich making up the camper walls) to determine where to cut through, to mount water heater frame properly. However, the only way to know for sure, is to contact Outfitter with your unit's serial number.
The best way to identify where the aluminum framing is located: on a summer/fall morning when there is a heavy condensation early AM, the outline of the aluminum frame will be VERY evident (the condensate will adhere to the outside camper shell mirroring the frame). You could then use a marking device to lightly mark the framing members, then create a CAD drawing of the entire camper shell framing structure using measuring tools. Same principal discovering aluminum roof framing (both outside and inside).
Good luck.
โMar-25-2015 05:25 AM
