โSep-15-2013 05:31 AM
โSep-15-2013 02:07 PM
nyokie wrote:
I have the bronco 1251sb, has the same lift system. The only info I saw and dont even remember where, probably the manual, only mentioned lubing the slides inside at full lift. I read its a permanently lubed worm gear assembly with push pull cables on the outside requiring no maintenance. Oh and tighten the screws holding the crank shaft every now and then, mine have a tendency to loosen.
Enjoy your new camper! Only issue ive had with mine was a small hole in the caulking on the roof front,the corner moldings, have a good look at yours every 6 months at least.
โSep-15-2013 01:24 PM
PalominoReal wrote:
nyokie
Yes we are, I'm taking the TC for a test next month. I bought my Real-lite used from someone in west Connecticut. I don't even know if there is a dealer around in CT.
โSep-15-2013 01:21 PM
โSep-15-2013 11:47 AM
โSep-15-2013 11:43 AM
โSep-15-2013 11:38 AM
RWDIII wrote:
At the end of July,Budman asked about the lift system in the Bronco.It should be
the same as yours.
I have a 2013 Bronco 800 and have had no problems.
the lift system is something the dealer has to take care of.
Did you get the LED lights,they are great for boondocking or dry camping.
I'd send a sticky but never got the hang of it.
Happy trails and Semper Fi
โSep-15-2013 10:36 AM
โSep-15-2013 10:30 AM
โSep-15-2013 09:35 AM
