LOFAT36's avatar
LOFAT36
Pocket door
Have a 2011 Rockwood TT model 8293RKSS. The roller bracket on one of doors has striipped threads and I need to replace it. Does anyone know if this would be a standard fitting or would I have to go to a Forest River dealer ?
  • Found the problem. The plastic piece you screw into on the wheel truck fell out. There is a gap on the inner walls and I guess it dropped in there, never to be seen again. Found a small nut that would fit inside the truck and put it back together. Thanks for the info.
  • Should be a standard item, either RV or from a building supply place. Look at JR Products or RV Designer- they likely have the part. Available from online RV parts/accessories vendors or a local RV dealer or independent RV shop.
  • Should be a mfg name somewhere on the hardware. If you cant find anything take it with you to a big box or lumber yard. Somewhere where your local builders shop and search their catalogues.
