ktmrfs wrote:
philh wrote:
ktmrfs wrote:
when boondocking we run it off the inverter as needed. We bought the smallest one we could get.
the one we have makes plenty of ice and the cubes seem to work just fine keeping the coolers cold.
How big is the inverter?
1000W, but most of the portable icemakers only draw maybe 100-15W W peak. IIRC mine draws a little over 1A based on the nameplate.
Next, there are only a few mfg of the ice makers. Most are just branded with dozens of other names. Heir (sp?) is one of the main mfg.
That 1A, is at 120V, turns into 10A-11A at 12V per hr when running. Startup surge will be 8 - 10 times the run current so startup surge can be as much as 100A-110A at 12V.
Ours pretty much never stops running unlike a home fridge conversion so your looking at needing close to 264Ahr of battery capacity per 24 hrs of operation for boondocking.. If the fan is running, so is the compressor.. Will take a lot of solar, battery and or generator for boondocking, plan accordingly.
We only use ours when camping with shore power.
