โDec-28-2015 12:51 PM
โDec-28-2015 07:52 PM
โDec-28-2015 06:40 PM
โDec-28-2015 06:28 PM
Diplomat_St_Poodles wrote:
The converter in your RV basically does two jobs.
1) When you are plugged into electricity it converts a portion of the 120 volts coming into the RV down to 12 volts so all of the 12 volt devices like overhead lights and fan motors will operate without draining the RV battery.
2) It has a battery charger built in the converter to keep the RV battery charged.
A bad element in the fridge will not normality cause a breaker to trip unless it has a short.
Unless the second plug is on another circuit it will likely not help your power situation.
โDec-28-2015 06:19 PM
โDec-28-2015 05:49 PM
As a temporary solution can you run a second extension cord for the electric heater? When we are camped where there is only 15 or 20 amp service we run a second extension out the window for the electric heater on a separate circuit.
Even if you are not turning anything on, the converter may be turning on causing the power to trip. Or the breaker heats up and trips.
Is there anyway for someone to show you how to remove the propane tank and have it filled. If the fridge doesn't work on power it may work on propane. Likely the heater element in the fridge needs replacing. Fairly simple process, elements usually cost less then $20.
Good luck.
โDec-28-2015 05:46 PM
STBRetired wrote:
Just to be clear, it's the breaker in the box on the horse shed that is tripping. It does not have a red or yellow button labeled "Test".
Stuff in you fridge is melting because it is not working. If the 120V power is on and you still get a "Check" light then there is something wrong with the fridge itself. Don't forget that the fridge uses 120V power as well as your space heater.
When you talk to the electrician, tell him you need a 50A RV hookup, which is really just a 25A 120/240 household connection. If the box at the horse shed has 240 power, which I suspect it does, then he could give you 50A RV service, which is really 2 25A household circuits. He might have been thinking you need a single 50A connection.
โDec-28-2015 05:40 PM
โDec-28-2015 05:17 PM
โDec-28-2015 05:15 PM
westend wrote:
The reason you can only have 30 amp installed is that there is a single 120V phase in that breaker box. I would suggest to buy a good 12 AWG extension cord and power your biggest appliance (probably the heater) with that cord. Connect the cord into a receptacle that is protected by a different breaker than the one you are using or install another receptacle on that different branch circuit at the breaker box. This setup will give you 40 amps of usable service and be cheaper than pulling new wire to a dedicated 30 amp receptacle.
โDec-28-2015 05:13 PM
hohenwald48 wrote:
On the extension cord the wire size is printed, stamped or embossed on the outer covering of the cord itself. It will say something like 16AWG or some number usually followed by AWG the number will be an even number. Probably 16, 14, 12 or 10 followed by the AWG. Smaller number is bigger wire.
As far as the size of the wire connected to the breaker it should be marked the same way. With newer wire the color of the outer covering will indicate what the size is but if the ranch wiring is more than about 10 years old you will have to read the data on the wire just like on the extension cord.
If you are plugged into an outlet located outside it should be protected by a GFCI breaker if it was installed according to electrical (NEC) code. If the breaker is GFCI it will trip due to moisture on the connections.
400 amp electricity to the main service entrance won't help much if the distribution wiring is not up to the task.
โDec-28-2015 04:55 PM
โDec-28-2015 04:51 PM
โDec-28-2015 04:44 PM
โDec-28-2015 03:55 PM
โDec-28-2015 03:38 PM
