โApr-15-2023 04:14 PM
โMay-06-2023 09:44 AM
3 tons wrote:
With LFPโs, Wishful thinking can also be fun ๐
3 tons
โMay-05-2023 11:22 AM
โMay-04-2023 05:09 PM
mbloof wrote:Sterling1 wrote:
For now I plan to use a volt meter I have installed in my camper for SoC level which should be good enough for my use. I've "calibrated" the camper meter with a multimeter at the batteries when the isolation switch is switched off to eliminate parasitic draw. So far there no significant difference between the camper volt meter and the multimeter but I haven't taken measurements when the batteries are in a low SoC.
Good luck with that. As an example on my NL that switch only breaks the connection to the Converter/charger - the jacks+controller and fridge are directly connected to my battery(s) bypassing that switch.
- Mark0.
โMay-04-2023 05:07 PM
3 tons wrote:
Follow-up to WarrenS65:
When it comes to accurate SOCโs, I kinda see the Bluetooth feature mostly as marketing gimmickry, while their real utility is for checking individual cell statusโฆFurther, it remains to be seen how the Bluetooth will respond to two batteries in parallel or series connectionโฆMy view is thereโs no substitute for the credibility of a Victron shunt based meter..
Of all possible features, the Bluetooth feature wouldnโt be high on my โmust haveโ list - JMO
3 tons
โMay-04-2023 04:18 PM
โMay-03-2023 07:46 PM
โMay-03-2023 06:05 PM
โMay-03-2023 04:53 PM
โMay-03-2023 03:23 PM
3 tons
Upon edit, the aforementioned Bluetooth SOC inaccuracy may be associated with personal charging practices, and the number of less than a FULL charge, charge cycles which overtime leads to cumulative meter drift, whereas the Victron could be FAR better at resolving cumulative driftโฆJust MOโฆ
3 tons
โMay-03-2023 01:34 PM
3 tons
โMay-03-2023 07:43 AM
โMay-02-2023 05:08 PM
DWeikert wrote:
A little late to the thread but just throwing this out there. Instead of 2 100ah batteries is there a chance you would have the space for one 200ah battery? For example -
JITA 12V 200Ah Plus LiFePO4 Battery
Wiring is much easier and solves the problem of trying to balance the cells across 2 different batteries.
My $0.02
Dan
โMay-02-2023 03:33 PM
โMay-02-2023 02:28 PM
