Mike134
Jun 12, 2023Explorer
Lantley wrote:Cummins12V98 wrote:Cummins12V98 wrote:Lantley wrote:
Taking the idea that GVW is a performance and manufacturer's rating only.
Does that mean GVWR doesn't matter and can be ignored?
I don't think so. All the ratings have some significance and should be factored into your decisions.
I never get a good answer on this one.
How can I load my rear axle to it's RAWR of 9,750# and not add a single pound to it's front axle weight of 5,250# and be within the 14k GVWR???
I got booted off IRV.NET over disagreeing with SmokyWren a monitor on this subject.
No one wants to tackle this one??????
If I understand correctly you can't load to the full rear axle rating without exceeding your GVWR.
Much in the same way you can't tow a 15k bumper pull RV without exceeding the hitch rating.
Sure you may be within one rating but exceed others. I'm not sure what's so complicated about that!
Not true. Last time I loaded my rear axle 200lbs more than it's 3800lb rating. That lifted more weight off the front axle so the trucks rating was never exceeded.
44,025 PostsLatest Activity: Feb 18, 2025
