RAM 6.7 Cummins 2500 OR 3500
rbos57
Going From RAM 2500 6.4 HEMI Gasser to either RAM 2500 6.7L C or RAM 3500 6.7L C
What do you all think, is there a huge difference?
Currently pulling 29RKS jayco tt
Looking to get a 5er about 14000#
29 ft tt
2016 RAM 3500 6.7 CUMMINS
58 REPLIES 58
spoon059
larry barnhart wrote:
Driving the truck was dangerous if wind was blowing . Up and down was ok but left to right it would lean so far it was tough to keep it on the road. Changed to a ford with leaf springs and the problem was solved. The ford wandered like fords do in those years and later and the reason for going to GM trucks.
chevman
Good point... I have heard that the Ram coil suspension is closer to the center of the truck than the old leaf spring setup, which could allow for more body roll.
2015 Ram CTD
2015 Jayco 29QBS
IdaD
Me Again wrote:
IdaD wrote:
That's a neat story about coil springs on a 60 year old truck. Should we compare a 60 year old phone to my iPhone next?
The payload rating on a 3/4 diesel is simply a function of the 10k lb GVWR class limitation. The 1000 lb lighter 6.4 2500 payload rating is accordingly 1000 lbs higher, and it has the same rear coils. Bottom line between a 2500 and SRW 3500 is you're splitting hairs in terms of capability and daily driving ease of use. Move to a DRW and now there's a real distinction on both fronts.
Put the same large truck camper on the two and see if you think they are similar.
Without going to air suspension, it is hard to soften ride and still be able to carry heavy loads.
RAM made a decision to differentiate between the 2500 and 3500 SRW when they but coils on the 2500. FORD and GM have not yet gone that direction.
Chris
I never said they were the same, just that the difference is pretty minor. If you do a search ib516 actually ran a back to back test with his 2500 and a buddy's leaf sprung 3500 (both 2014s) using a fifth wheel with around 3000 lbs of pin weight. The coils sagged .7" more, although because it rides a bit higher unloaded, the loaded difference between the two was a bit under half an inch. Huge difference, right?
2015 Cummins Ram 4wd CC/SB
larry_barnhart
I had a 3/4 ton GMC with coil rear springs. Bought a 8 ft Bell super 8 camper.
chevman
chevman
2019 rockwood 34 ft fifth wheel sold
2005 3500 2wd duramax CC dually
prodigy
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
Grit_dog
Nomad III
Nomad III
The obvious choice is get the truck with plenty of factory payload, 3500. But as you can see, looking at different rawr ratings, they are not necessarily derived from the real world capacity of the axle tires and wheels. Maybe suspension is limiting factor, maybe class gvw is the limiting factor, but understanding the lack of availability of 3500s on the lots as you say, you can safely accomplish pulling a 14k 5vr with a new 2500 if that's the way you choose to go.
Go look at 2500/3500 models. You'll see the different rim options used interchangeably between 6klb rawr trucks and 7klb rawr trucks. Means that rim combo is good to at least 7klbs.
One other consideration is the tpms req on 2500s vs 3500s it's an annoyance and will cost you a bit to find a dealer to re set the tpms on a 2500 if you intend on airing down the tire when empty driving.
I'd be on the fence but swayed to a 3500 just because I've been annoyed by having to re do the tpms thresholds on my last 2 F250s.
mkirsch
Nomad II
Nomad II
Of course we should. Clearly, no technological advances have been made in the last 60 years. It was bad once, therefore it will always be bad.
We should absolutely lump a triangulated 4-link with panhard bar in with the crude wishbone deal that they had on the '67-'72 Chevys. They're exactly the same.
Me_Again
Chris
IdaD
Me_Again
I guess some are not old enough to remember the early 60's Chevy's that had coil rear springs. Ford's and GMC's for years handled loads better until Chevy finally switched to leaf springs. Chris
transamz9
Me Again wrote:
IdaD wrote:
transamz9 wrote:
Pretty much what I'm seeing is that the 2500 gas trucks are 6000 but the 2wd crew cab diesels and Mega Cabs are 6500. The old thing is the 4wd crew cabs are 6000. Also I just realized the offer a 2500 cab chassis (bed off) truck now. It also carries the 6500 RAWR. The 3500 SRW trucks are 7000 across the board.
The 6.4 and CTD trucks with 18/20" wheels are all 6,500. That's going to constitute the bulk of 2500s sold these days, or at least it's the vast majority of what I see out on the roads.
This is mine. Crew cab short box 4wd Cummins.
So, if my 3500 has the same tires and a RGAWR of 7K, RAM must think that the leaf springs can carry more weight than the coils?
They also think/say my short box 3500 can carry 1700 more cargo. If it was a long box that number is 2300 more. Chris
That 1700 and 2300 number you are getting is just because the 2500's GVWR is set at 10,000 pounds to keep it in the class classification. If they went above the 10,000# GVWR then it would be in the same class as the 3500. As far as the spring's capacity, I don't believe they set the rear weight capacity according to what the springs will handle. I believe they set it at the way they handle a load for the classification of the truck. In most cases the 2500/250 class trucks are bought and used differently than the 3500/350 class. I've seen mini vans with as much payload capacity as 2500's. Example: Look at the springs on a cab chassis 3500 compared to the springs on a 3500 pick-up.I have personally had the rear axle weight 13,000# on my 2006 F350 service truck and it was not sitting on the bump stops. Put 10,000# in the back of your 3500 and tell me how she looks.;)
2016 Ram 3500 Mega Cab Limited/2013 Ram 3500 SRW Cummins(sold)/2005 RAM 2500 Cummins/2011 Sandpiper 345 RET (sold) 2015 Sanibel 3601/2008 Nitro Z9 Mercury 250 PRO XS the best motor made.
Me_Again
Cummins12V98
My POINT was a general comment not directed at you. Many on here don't understand what the reality is on tow ratings.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Greene728
Cummins12V98 wrote:
Greene728 wrote:
I have a 15 3500 SRW. And with the tire pressures set accordingly I find the ride to be very good and responsive for a 1ton truck. It's my DD also and couldn't be more pleased. Payload on door jam with the CTD is 3985#. Next best 2500 I found similarly equipped was roughly 2300#'s. No brainer for me. And I actually got the 3500 for just over $350 more than a similar 2500. Again, no brainer if you're even considering a 5th wheel.
Best of luck with your choice which to me is crystal clear!
Just remember that "payload of 3,985# is distributed between the front and rear axles. The reality is once you have all your bodies gear and hitch in the truck there is plenty of weight capacity left on the front axle that you will only add around 100+# to what hooking the 5er. The weight of the rear axle subtracted from the RAWR is what capacity is what is left.
My point is those numbers are NOT reality you need to understand how they work.
I understand what your saying and I'm aware of how the number's work. What I don't understand is your point.
2011 Crossroads Cruiser 29BHS ( Traded )
2017 Grand Design 303RLS ( Sold )
Currently camperless ( Just taking a break )
2016 Chevy Silverado 2500 4x4 6.0 and 4:10โ€™s
Me and the wife and our two daughters. Life's good!
transamz9
transferred wrote:
I see, so the wheel/tire upgrade is what's doing it. I was just going by Ram body builder. Makes since. The standard 17" tire is not rated high enough for the 6500.
Boy, if I could get a 2500 with an Aisin I would be set!. A 3500 SRW Limited is impossible to come by without ordering. I have seriously thought about trading my 3500 for a 2500. If I could only get the Aisin/HO Cummins. I wish Ram would just let you choose what drive train you want in which truck.:S
How come you're tempted to change your 2500 for a 3500? Empty ride quality?
Because it is very hard to find a srw 3500 Limited that is loaded to the gills. 2500's are easier to find because that's what on the lots.
IdaD
Cummins12V98 wrote:
transferred wrote:
Cummins12V98 wrote:
So the reality is the 2500 and 3500 SRW trucks have only 500# RAWR separating them when properly equipped?
The reality is the 3500 SRW is rated to carry c.1,500 lbs more weight making it the correct choice over the 2500 everyday of the week and twice on a Sunday. ๐Ÿ™‚
Did you read the two charts on the last page I posted with the rear axle weights shown to be 6K on the 2500 and 7K on the 3500 SRW's?
My math shows 1,000# difference. Where do you come up with 1,500#?
I'm sure he's basing it on payload rating, although on the 2500s that figure is restricted due to the truck class max 10k GVWR. It's simply an on-paper restriction that matters to some and doesn't matter to others.
And again, in most cases the RAWR on the 2500 is 6500 lbs, not 6000 lbs, which makes for a 500 lb difference.
