Ram Asin Trans fluid
tinner12002
I was looking through my manual today and noticed that the Aisin tranny requires a special fluid with code JWS3309. When I find an fluid with that spec it lists a series of manufacturers but not the Ram. Has anyone had this issue on their newer Rams with the Aisin trans?
2015 Ram 3500/DRW/Aisin/auto/Max tow/4.10s,Cummins, stock Laramie Limited--Silver
Tequila Sunrise 2012 Ultra Classic Limited
2018 Raptor 428SP
13 REPLIES 13
Cummins12V98
FishOnOne wrote:
Cummins12V98 wrote:
WTP-GC wrote:
Cummins12V98 wrote:
Book says to "change" at every 30K does not say partial. Book says to change filter at 120K.
I read other forums too...
The following discussion was particularly interesting...perhaps you're aware of it...
Some people never give up!
Of course I am aware of it. I stand by what I said here and there.
I'm so glad I don't have to change my fluid until 150k miles. Thanks for comical link. :W
Notice the nitpicking stopped when I called them out on it.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
FishOnOne
'12 Ford Super Duty FX4 ELD CC 6.7 PSD 400HP 800ft/lbs "270k Miles"
'16 Sprinter 319MKS "Wide Body"
Cummins12V98
WTP-GC
Duramax + Grand Design 5er + B & W Companion
SBGTF
Cummins12V98
WTP-GC wrote:
Cummins12V98 wrote:
WTP-GC wrote:
X2 for the Mobil ATF 3309. I believe they say its a 6.8 quart change. I used a full 7 quarts, FWIW.
7 quarts out of 13.7 is not much of a "change".
Just following the manufacturer's recommendations for service at the specified intervals. Next "change" will be a full "change".
Cummins12V98
tinner12002 wrote:
Not to the point of having to change it yet but thought I'd look ahead to see what others were doing after seeing a comment of someone getting charged about $500 for a fluid change! Seen they run special antifreeze also so I'll be getting some of that too. Thanks for the insight Cummins12V98 on changing the fluid!
Coolant is good for 150K.
You R welcome!
ramgunner
Mobil 3309 is the correct fluid.
Editor - http://www.RamGunner.com / http://www.MomentumGunner.com
2014 Ram 3500 Tradesman/CTD/AISIN/4.10/4WD/CC/LB/DRW/VHF/UHF/APRS/CB/SCANNER
Grand Design Momentum 385TH (Polaris RZR800/VHF/UHF/HF)
WTP-GC
SBGTF
tinner12002
2018 Raptor 428SP
Cummins12V98
WTP-GC
SBGTF
Cummins12V98
Look on AMAZON. Great deal on OE Mopar fluid delivered to your door $44.76 per gallon.
4 of Genuine Chrysler Accessories (5189977AB) AS68RC Automatic Transmission Fluid - 1 Gallon
Sold by: autopartsmopar
$44.76
Changed the fluid on my son's 3500 RAM last weekend. Draining JUST the pan 8 quarts came out. Removed the pan and filter an additional 2 quarts came out. I popped the line at the radiator but only a little over 1 quart came out before it turned RED. So we removed about 11.5 quarts out of 13.7 total fill.
The 3 bolts holding the trans to the cross member need to be removed and raise the trans up tim it stops to get to the 4 bolts at the front pan. NOT an easy task!!!
My Son used the AMZ/OIL ATF.
azrving
2014 here. I used Mobil 3309 atf after searching turbo diesel register and other CTD sites. I bought the Chrysler transfer case oil on Amazon and run Mobil 1 in the pigs. DO NOT mix up the coolant. There are a few different ones and mine uses HOAT. It specifically warns about using the exact coolant. It may appear orangish at times depending on the light angle but it's purple. I bought it at the dealer.
Did you download the diesel supplement?
