- SidecarFlipExplorer IIIIf the Ph of the water was high, it would cause surface rust (and eat up your anode rod quick too....
- brinsonExplorer
SidecarFlip wrote:
brinson wrote:
Well, brought the camper to a local dealer to determine the source of the rust and they pressure tested it with the electric heat on for 2 hours and no leak was detected. While there I noticed a rust stain in the bottom of the relief valve vent making me think at one one time it was relieving. Of course Suburban will not do anything unless there is a leak or crack. I'm wondering if the relief valve may be the source of all the rust.
At this juncture I have to ask what the Ph of your fill water is? Sure looked like a bad bung to me too. Your T&P valve could have been weeping and caused that if the Ph of the water was acidic. T&P valves are cheap and Lowes will have many in stock.
Not sure what the Ph of the water would be as this was filled at Tom's Camperland in Arizona. I discovered the rust when I got home with the camper. I will change the valve. - ljrNomadMine rusted through but it took 5 years.
At this juncture I have to ask what the Ph of your fill water is? Sure looked like a bad bung to me too. Your T&P valve could have been weeping and caused that if the Ph of the water was acidic. T&P valves are cheap and Lowes will have many in stock. - brinsonExplorerWell, brought the camper to a local dealer to determine the source of the rust and they pressure tested it with the electric heat on for 2 hours and no leak was detected. While there I noticed a rust stain in the bottom of the relief valve vent making me think at one one time it was relieving. Of course Suburban will not do anything unless there is a leak or crack. I'm wondering if the relief valve may be the source of all the rust.
- brinsonExplorerWill do, it will be a few weeks as I will be in Arkansas for a week or more.
- Old-BiscuitExplorer III
brinson wrote:
Got it scheduled to go to a local rv shop after talking to Suburban. After they diagnose it, they are to contact Suburban to work out warranty details. Thanks for the help.
Come back and post results...outcome. OK - brinsonExplorerGot it scheduled to go to a local rv shop after talking to Suburban. After they diagnose it, they are to contact Suburban to work out warranty details. Thanks for the help.
- lakeside013104Explorer
SidecarFlip wrote:
Old-Biscuit wrote:
Time to return to dealer and have it swapped out for another one under warranty
You have a leak,,,,,,,
electric element seal'
Anode rod bung weld is cracked
Your pic is upside down
I agree. It's under warranty and your bung weld is failed (as Old Biscuit) says.
To the OP:
If Old Biscuit and SidecarFlip both agree that you have a broken weld, you can bet your bottom dollar, 'that' is the problem. Both these gentlemen have many years RVing experience and even more years experience solving life's problems than most viewers of RV.net.
My two cents worth. Worth what you paid for it!
Lakeside - bitster98ExplorerWow!!! That's a new water heater. I would suspect an electrical current is causing that.
About Travel Trailer Group
44,025 PostsLatest Activity: Feb 06, 2025
