FreebirdFlies wrote:
Just... Wow!
Water does NOT get on the folded wall panels while going down the road (it is CLOSED then).
The camper top closes and seals when it is down in the travel mode.
Have you ever even SEEN an Alaskan camper transition from down to up, then back down?
Your talking nonsense here if I take your words at face value!
Reading is fundamental...or apparently not in some cases.
WHERE did I state the water got on the panels AFTER they were stowed?? The conversation that you apparently jumped into without reading the whole thing, is about what is on the panels at the time they are stowed and where it will end up.
Yes I have indeed seen an Alaskan, as if you have followed what I posted I clearly stated it was the FIRST brand I chose to look at during our pre-buying information gathering process (before I had even heard of Outfitter/Northstar/hallmark). At that time I also spent quite a bit of time on the phone with Don or Bryan Wheat (can't remember which it was after 12 years) discussing what they could and couldn't do as far as options/modifications and costs go.
