- BumpyroadExplorerI would "assume" that Casita could make something that fits your desires.
bumpy - theoldwizard1Explorer II
lots2seeinmyrv wrote:
Lil Snoozy
Nice to see them back in business ! I think they should add a longer version. - BobboExplorer IITry Scamp or T@B too.
Although, you may have trouble finding one, of any brand, without a gas furnace. The refrigerator and water heater may or may not be available with electric. As long as those have an electric option, you can just not use the propane. - MarkTwainExplorer
rv bill-e wrote:
Need a TT no more than 21', will always have full hookups and never use propane. Does anyone make such a thing?
Just curious, what is the advantage of not using propane? - 2112Explorer II
- rv_bill-eExplorerHey, thanks for all the quick replies! That Lil Snoozy looks perfect, wish that I could find a used one, but they are rare. I understand that most will come with propane system and I can just ignore it, but do need electric hot water and heat. Will be used in one location without moving for several months a year, will have sufficient electric available, and would rather not deal with trips for propane refills.
- lots2seeinmyrvExplorer
You could always find a used Casita. They do have electric water heater and you can use an electric space heater and not deal with the propane at all.
Just ignore the propane. - carringbExplorerI would focus on finding a trailer you can live with/in, as long as it has the electric water-heater option. Suburban allows you add electric later. Dometic can be converted with a "hot rod" that replaces the anode rod. It works great, but technically voids the warranty.
For heat, either add an electric fireplace if there's space (that's what I use on my trailer) or add a heat-strips to your A/C.
For cooking, you could use a portable inductive stove. And if you do use propane for cooking only, it'll last a very time.
Beware that most of the small lightweight trailers are NOT intended for full time use. The warranty might even be voided. You can into issues like condensation damaging adhesives, and the composite floor breaking down with frequent traffic.
I suggest looking into something built well, like Nash.
https://northwoodmfg.com/travel-trailers/nash/nash-17k-2/
About Travel Trailer Group
44,029 PostsLatest Activity: Jan 13, 2025
