earnesttee
Aug 20, 2014Explorer
Smell in rv
What causes the sewer smell in rv when dumping black tank.Ihave smaller tanks I have been told to dump more often any help would go a long way Thanks
rockhillmanor wrote:
It should NEVER smell inside the RV when dumping period.
DutchmenSport wrote:
I have noticed on occasion,at some full hook-up camp sites that when the neighbors (sometimes) drain their tanks, or when leaving the campground, the "poop" odor is awful in the air. Now everyone agrees their own "poop" does not stink, so this does not apply to YOU. It applies to the camper parked beside you .... right?.......
~Be a good camping neighbor!~
Dtaylor wrote:
A lot has to do with how clean you get your tanks when dumping. If stuff is left in the tank from the previous time, the smell does get much worse. The next time you are someplace with full hookups, fill a 5 gal bucket with water from the shower and pour several into the toilet with the sewer valve open. On occasion, before leaving home, I will dump 5 gallons of water into the tank and 1/2 gallon of bleach. It is also a good idea to have water in the tank before you begin using it. Also, a grey tank can smell just as bad as the black tank.
