BFL13
Feb 13, 2015Explorer II
Spark Plug Change in a Truck--How Hard Can it Be? Update#2
Update-fuel filter only- 26 Feb 15.
Update 2- 28 Feb
The 2003 Chev 2500HD 6.0 Gasser we got new with now 150,000km on it is getting cranky going up hills while towing. Lots of snappy bangs and the engine light comes on flashing till we get to the top and ease off.
Chev dealer shop guy said it was the fuel/air mixture sensor being dirty and they cleaned it off some as a fix. The fix worked for a while but not for long. He said I really needed new plugs and wires and maybe a new fuel filter.
So first question, could it all be the fuel filter's fault--that is easy to take care of. (supposed to swap that every so often but it seems I never have, so that is not an option now. Will do)
Next thing is a couple shops I went to both say it is a two- hour job to change the plugs so labour is $200! The cost of the plugs seems ok although that is confusing.
GM I think uses platinum tip but another place says their replacement for that is an iridium tip. But a third shop says there are different qualities of iridiums and platinums so how can you know what is equivalent to what? Is a $10 (vs a $20) iridium as good as a $10 platinum?
The wires come in two forms where we have the "square" coils and some have the "round" ones. Whatever. I am scared to touch them. The GM shop said I might not need wires. How can you tell if you do?
Years ago I just bought plugs and wires and changed them myself. Got the spark plug piece in my tool box. (3/4 inch?) This looks way too scary with those coil things there, but is it really? I don't mind the price of the plugs and wire kit, but that labour cost is crazy if I can just do it like before in simpler times. I don't care if it takes me all day instead of two hours! :)
So, how hard can it be? Or do I just pay up and not have to worry about it for another ten years or so?
Thanks.
Update 2- 28 Feb
Thanks.
