tkhollywood
Jun 30, 2014Explorer
sticky entry door
Well on our first trip with our new TT and for some reason the door sticks when you go to open it. After you get it open it will open and close fine. Then let it sit closed for a wile and it sticks again like it is hung up on something. Already have a new outdoor kitchen door on order for a warped door so should I have them replace the entry door as well. Also have to have one of the crank out windows replace for a bent framework the crank out is popped the guides right out of the frame and the only way to get them back in is to drill out the rivets and reattach the guides then re rivet.
So should I finish out the season then bring in for repairs or get them done asap. I am a little worried about t b E window not sealing proper and water getting in or blowing the window off the trailer while in tow.
