bmanning's avatar
bmanning
Surprising discovery: 5-speed vs 6-speed automatic
As some of you know from other threads I am trying to help my FIL find a Sequoia for grand kid duty.
In doing general research I looked into the ratios of the 2005+ 5-speed (behind the 4.7) vs the newer body style's 6-speed (behind the 5.7) to see how much of an "edge" the newer 6-box brought to the table. I was surprised to learn that the 6 is just the 5 with an extra OD ratio-- no deeper first gear, identical ratios.
Current gen 6-speeds are thought of as the cat's meow for towing, but if the vehicle in question is a Sequoia, there's no advantage to be had there except running empty on the freeway.
No question that 6's have advantages over older 4's, but over 5-speeds- especially in Sequoias specifically- there's little to be gained by having the 6-speed.
Just found it interesting; I expected a deeper 1st & different ratios but not in this case.
