joelyn's avatar
joelyn
Temp. Sensor???
on a 2012 ram 1500 crew cab does anyone know where the sensor should be for the temperature reading in the truck on the dash??
  • I believe '12 and older, the temp sensor is mounted on the rad support.
    From '13 and newer it is located on the bottom side of the drivers side mirror arm.
  • ScottG wrote:
    Look to the right of the radiator as you face it - at least that's where mine is.
    My sensor on a '13 reg cab is located in the arm of driver's side mirror.
    I was GOING TO CORRECT YOU :B However,apperantly it was located behind the rad on previous year models :S
  • Look to the right of the radiator as you face it - at least that's where mine is.
