Dec-13-2015 07:38 PM
Dec-17-2015 03:19 PM
SoundGuy wrote:Supereri73 wrote:
So you realized the confusion was already cleared up, but you still felt it necessary to reply in such a condescending manner? Ok, check. Got it.
"Realized the confusion" after a lot of unnecessary head scratching trying to figure out what you were talking about! :h Apparently what you're saying is that because you can't be bothered to read a discussion in it's entirety and understand what really has been said you're fine with posting a reply anyway that makes no sense at all - "I too have never heard the interior frig light referred to as the door heater... Funny." - leaving the rest of us who have read what was actually previously posted completely confused as to how the heck you came up with such an erroneous conclusion. :h And now you're chastising me?! :@ Good grief. :R
Ok, check. Got it. :R
Dec-17-2015 01:51 PM
bobndot wrote:Thanks Bob,
Battery shut off disconnect is the simple solution during storage .
I camp w/o any hookups . To save my batteries while at camp or during storage........
* I pulled the fuse on the detectors. I use two portable units.
* Installed a toggle switch on the radio. Kills the clock/memory.
* Disconnected the 12v. TV power plug which was always in a standby mode.
* Made sure my roof vent fans (I have 2) were dead when turned off.
Some roof vent fans (not all brands/models) always have a slight draw while off.
My only .35 amp draw while camping is my fridge while running on gas.
During storage the fridge is off... zero draw on the trailer. Its all dead with the battery still hooked up.
one of the members did this workup.
Current measured with battery at 12.68 volts.
- CO & LPG detectors together draw .061 amps (0.77 watts)
- Norcold 6 CF running on LPG = .609 amps (8.5 watts)
- Forced air heater running = 3.49 amps (44.25 watts) 20k btu unit
- Dual bulb florescent fixture = 2.15 amps (27.25 watts)
- One overhead incandescent bulb = 1.45 amps (18.38 watts)
- Northern Breeze Fan on max speed = 3.99 amps (50.6 watts)
- Northern Breeze Fan on 1/2 speed = 1.15 amps (14.57 watts)
- Northern Breeze Fan OFF = 0.049 amps (0.62 watts)
- Cheapo Bathroom ceiling vent fan = 1.24 amps (15.71 watts)
- TV Antenna Amplifier = .041 amps (0.52 watts)
- Ventline range hood exhaust fan on HI = 1.32 amps (16.73 watts)
- Ventline range hood exhaust fan on LOW = .622 amps (7.89 watts)
- Ventline range hood exhaust fan light = 1.38 amps (17.49 watts)
- Stereo/DVD player with power off = .057 amps (0.72 watts)
- Stero on FM at mid volume = 1.1 amps (14.94 watts)
- 'Go Power' 300 watt PSW inverter 'ON' mode = .23 amps (2.9 watts)
Dec-17-2015 12:11 PM
Dec-17-2015 12:06 PM
Dec-17-2015 11:10 AM
Jeez, tough crowd. The confusion was already cleared up before the condescending post. I said "Uh hmmm. Not as funny as I thought. There is an actual anti-condensation feature that uses a heater.... ". But, some just refuse to read the words right in front of them. :S
Oh I read your retraction alright ... but the point is none of this would have come up if you'd just taken the time to read the prior discussion in it's entirety, including links that provided all the information needed to clearly understand what was being discussed, before hitting the keyboard in response. Seems to be a common ailment here on the forums. :S
Dec-17-2015 05:25 AM
Dec-17-2015 04:15 AM
Supereri73 wrote:Yea, I had to block him. First time I had the need but I'm happy the option is available.SoundGuy wrote:
There shouldn't be any confusion - some just refuse to read the words right in front of them. :S In my own previous post I included a link to 2 pics of this same mod and the text included says quite clearly - "Running to the light switch are two red wires - the lighter gauge wire feeds the light, the heavier gauge feeds the climate control heating element. I cut this heavier wire and wired it through a switch so I can turn power off to the heating element, thereby reducing unnecessary draw on the battery." How much clearer could that be? :h
Jeez, tough crowd.
Dec-16-2015 08:42 PM
Dec-16-2015 07:41 PM
Supereri73 wrote:Supereri73 wrote:Tvov wrote:
A "door heater" for a refrig? I have to admit I had never heard of that!
Dec-16-2015 01:10 PM
SoundGuy wrote:Tvov wrote:
A "door heater" for a refrig? I have to admit I had never heard of that!Supereri73 wrote:
I too have never heard the interior frig light referred to as the door heater... Funny.ADK Camper wrote:
In my original post I said:in my refrigerator model the wire carrying power to the door heater ran thorough the inside light housing. I cut the wire, installed a switch in series, and mounted it in the housing.It is in fact not the same wire that carries power to the refrigerator light. A separate wire goes to the heater. It just happens to be routed through the light housing making it a very convenient point to access. Hope this clears up any confusion.
Dec-16-2015 11:00 AM
Dec-16-2015 10:49 AM
Dec-16-2015 07:54 AM
Dec-16-2015 06:39 AM
