dwightr8's avatar
dwightr8
Tires for Shadow Cruiser 260BHS
Replacing the tires on our Shadow Cruiser 260BHS. Going to go with Goodyear Endurance. I'm thinking of upsizing from ST205/75R14 to ST215/75R14 to get a little extra load carrying capacity (gain 640#). I think the rims are 5.5" wide and there is plenty of clearance. Any problems?
Thanks,
  • Thanks for the reply My trailer is a Radiance by Cruiser RV
    I don't think those tires are on My trailer, but the ones on my trailer is also some strange name, I had never heard of. I only have 1200 miles on mine, and am not sure if I will keep them after the first year.
  • bob2194 wrote:
    I have a new cruiser Rv a different model. how did your tires hold up? If you don't mind telling what brad did they come from the factory. Just trying to decide if I should dump the factory tires. Thanks in advance.
    These are tires that came on the trailer:
    https://www.lionsheadtireandwheel.com/Vail-Sport-Radial-Tire
    In doing some research into them, I think we got really lucky. We have had no problems in about 15,000 miles including a trip to Alaska and back via the Alaska Highway. If I had known then what I know now, I don't think I would have done that trip on them. Ignorance is bliss!
    Good Luck,
    Dewey
  • When we had got our Shadow cruiser they came with bias ply tires, and they were horrible, the trailer would just sway side to side, I put some Carlyle radials on an the trailer towed like a dream. and we put many miles on the unit, when I sold the trailer the tires still had atleast 50% tread left.
  • I have a new cruiser Rv a different model. how did your tires hold up? If you don't mind telling what brad did they come from the factory. Just trying to decide if I should dump the factory tires. Thanks in advance.
  • Increasing the tire load doesn't increase the axle rating. I switched to D rated tires after seven years on my C rated tires.
    The new tires are rated C at 55 psi and D at 65 psi. I usually run about 60 psi to soften the ride.
    A trip to the CAT scales when fully loaded for the road, showed the TT axle weight was only 5600#s on the 7000# axle pair rating.
    Shortly after purchasing the new tires, I discovered that a rim bending road hazard or metal shard, does not care what the tire rating is or what they cost. :)
    Thanks,
    Excellent choice.
    26.1 vs 26.7 diameter ....or just over a 1/4" less space at the top of the wheel well to the top of the tire. Simply not enough to worry about.
    I like a taller tire as it lets the vehicle ride a bit better. Going to a load D tire increases harsh ride ie; over RR tracks/potholes or just a rough road surface.
    Now if I needed more load capacity in my tires to carry more weight then a load range uprate would be a good option.
  • I'd stick with the 205's the 215's will add to the diameter and you may get closer to bottoming out the trailer on the tire.
    I assume you have load range C now is that right? If you want to upgrade load range just stick with the same size and go to load D but make sure your wheels can handle the extra 15psi per tire too.
    Good point on the extra 15psi. I hadn't thought about that. I'm trying to find out from Cruiser if it's a problem. I did find out my wheels are 5" instead of 5.5" so I will be staying with the 205's even though the diameter is the same for both.
    Thanks
  • If the rims are indeed 5.5" then go for it. They both use the same air pressure and the diameter difference is very little.
    Thanks,
