Aug-24-2022 04:58 AM
Aug-24-2022 05:51 PM
Aug-24-2022 05:14 PM
Aug-24-2022 04:50 PM
tealboy wrote:
Hey folks, I’m looking for a new tow vehicle for a rig coming in at 2700 lbs, loaded, per the scale. I decided to trade down to a more modest unibody suv like the highlander, telluride or similar with tow ratings of 5000 lbs.vs my customary Tahoe or sequoia since I tow infrequently (3-4x/year).
However, I discovered something I was unaware of, these vehicles often come with a 1000lb limit when trailers are “Unbraked”. My trailer does not have brakes, seems many in this lower weight class don’t, though some do. My state law requires brakes at 3000lbs.
This discovery caused me to to rethink the mid size suv and go back to the sequoia or a Tahoe. I was shocked to realize the big sequoia with 7500 lbs tow rating is also limited to 1000 lbs Unbraked. The Tahoe is 2000 lbs. The gm line of 1500 series pickups also 2k.
Wow. It seems the manufacturers are providing very conservative figures for Unbraked trailers due to liability so no matter what I pick outside of a 2500 series, I am out of compliance with manufactures recommendations/requirements and potentially subject to liability in an accident even though I’m within state law.
I know this group is far more informed than average people relative to towing but I see tons of smaller to mid size trailers like mine, including many boats, without brakes and suspect most are totally unknowing of these low thresholds bc the manufactures brag about high tow ratings but you need to look much deeper for the Unbraked limits .
I’m not sure what to do now. Thoughts on the subject and your awareness of these vehicle limitations?
Aug-24-2022 04:23 PM
valhalla360 wrote:RetiredRealtorRick wrote:
Mathematically looks great, but I'm not sure it works exactly that way in real life.
Probably depends on conditions but I wouldn't be surprised to find than it's not uncommon to require more than a 25% increase in braking distance.
Aug-24-2022 03:36 PM
BB_TX wrote:tealboy wrote:
…. …….. The F150 for example Has a unbraked limit of 1500 lbs.
Where did you find this information? I have looked thru my manuals and cannot find anything addressing this. Not questioning you. Just curious where to find it.
Aug-24-2022 03:01 PM
Grit dog wrote:
Consider the source Scoob. Heck, you can't even lock up any brakes on virtually any vehicle from the last 20 years.
But, if not having trailer brakes, ONCE, lol, for 10 miles is a memorable event, unless that 10 miles was down Wolf Creek Pass, one should probably reserve comment....
Aug-24-2022 02:36 PM
Aug-24-2022 02:14 PM
mkirsch wrote:valhalla360 wrote:Grit dog wrote:
There’s a reason the law in many/ most states is 3klbs max with no brakes.
Probably dates back to the 1920s when 25-35mph speed limits were the norm.
Then all the old guys complained that they didn't want to pay to add brakes, so this was the compromise. Never been updated since then.
Do you have an historically accurate source to suggest why 3k lbs was chosen?
1920's? Motor vehicles BARELY had brakes in the 1920's, let alone trailers. The guy who invented trailer brakes wasn't even a glimmer in his father's eye in the 1920's, LOL (probably not really but you get what I mean).
Again, 95% of the time when you make up numbers, you look silly.
Aug-24-2022 01:07 PM
Aug-24-2022 01:01 PM
JRscooby wrote:valhalla360 wrote:
So if your SUV is 5400lb, that means the trailer is adding 50% to the weight that it has to stop...plus what other gear/people do you have in the car.
I've had the trailer brakes not work one time and I went slow the 10 miles to get home...it took forever to come to a stop from speed. Not something I would want to repeat.
Also, there is the issue of keeping things in line. If the SUV rear axle starts to slide in a panic stop, the trailer is going to try and push it around into a jacknife. Trailer brakes will try to keep everything in line.
As suggested, see if you can add brakes to the trailer. There's a reason manufacturers provide much higher tow ratings when the trailer has brakes.
Rear lock up? You hope. The TW reduces weight on the front, increases on the rear. Plus light vehicles are expected for front to do most of the stopping. (Bigger brakes) So it is much more likely for the front to lock up. Remember when you where a kid, would lock the rear brake on your bicycle and go sliding? Good fun, and only wore out the back tire. If the front wheel ever locked the wear was on knees and elbows.
Now later, ever try to stop on ice, feel front sliding? You have no control over direction.
Now I know your modern ride has anti-lock brakes, will release the brake on the wheels that want to slide. But if that slide is happening because you are stopping more weight than system is designed for, and a smaller percentage of that weight is on front wheels, anti stop brakes. But you can steer into something cheap.
Aug-24-2022 12:06 PM
Aug-24-2022 11:38 AM
Aug-24-2022 10:42 AM
Aug-24-2022 10:10 AM
Aug-24-2022 09:45 AM
PButler96 wrote:
You should know by now if you've spent a minute reading these boards that you need an F-550 to pull a 2900 lb trailer, let alone stop one.
