d3500ram
Oct 01, 2016Explorer III
Where can I get Heki skylight hinges?
Anyone remove the Heki skylight for maintenance?
I need to reseal around the Heki skylight. It is more than just adding sealant to the existing, I need to hog up the old and install new. The sides and back are not a problem, but the front hinge side is a royal PIA! The only way to access the sealer is to remove the skylight.
To remove it, it seems as if I need to cut the hinge pins. They seem to be one time use in that they snap into place upon seating. I am going to dremel the old ones off and use nuts with a long bolt of appropriate diameter for temporary, but I would like to get original equipment back in it.
Anyone know of a place (in America) for Heki parts?
