azwildcat99's avatar
azwildcat99
Which Year Suburban 2500?
We are thinking about getting rid of the truck in sig and moving to a 3/4 ton Suburban. We've taken two cars on occasion to accommodate family/friends in addition to my family of 5 and expect to do it more often. My dilemma for the burb is which year?
I like the NBS ones and think it will pull my trailer well with the newer 6sp tranny but I have heard the hitch is a weak spot. My trailer has a GVWR of 9000lbs and last I had it weighed with my truck and WDH attached the trailer axle showed 7k. I was at 15.5k total and my truck weighs about 6850 unloaded (2350 payload per yellow sticker). Unfortunately, I didn't weigh the trailer by itself, but let's assume I'm at least at 8k (yellow sticker shows 6600 empty).
Is my trailer too much weight for the hitch of the newer ones? Do I need to look for the classic with the 8.1? I worry that the older 6.0/4sp will make climbing the hills out of Phoenix not fun, even with a 4.10 rear. Especially coming from my current Duramax.
If anyone thinks payload will be an issue, let me know your thoughts on that too. I think I'll have about 300lbs to play with once family and trailer are hooked up with a payload cap of about 2100 in the newer burb. Do the older ones have more payload?
Also, I will be getting a 4x4 so a van is out of the question. Plus I don't want a van. Also, I am not sold on the Excursion either so let's limit the posts to the GM twins :)
Thanks in advance for the responses!
