jarbra15's avatar
jarbra15
DIY Pacbrake Install
Has anyone installed their own Pacbrake? Just wondering how tough of an install it is. Installing on 2001 Dodge Cummins w/auto tranny.
  • The early versions of the 47RE had too small of a thrust bearing and they would eat themselves up. Manual trans and you are good to go.
    Paw Paw John wrote:
    Banks has an exhaust brake you install in the exhaust piping and has a transmission module that shifts the trains into the next lower gear as the rpm drops. I'm thinking of installing this system on my F350 Dually 4X4 7.3 liter. Will also have to install 4 inch exhaust system from the turbo back.
    Google 7.3 exhaust brake. The 7.3 has a valve on the back of the turbo that can be turned into an exhaust brake on the cheap. With a few wiring mods, the converter can be locked up at the same time the valve is activated. All for less than $40! Make sure your third brake light works.
  • I installed a Pacbrake PRXB on my 06 RAM. It has the 48RE. The 06 model year is factory rated to use an exhaust brake. The brake control fully integrates with the ECM and Tow/Haul function. Works really well and you have on board air since the Pacbrake uses high pressure air for activation.
    The hardest part was getting all the parts close enough together to reseat the two V band clamps. Ended up using ratchet straps to pull them together.
    Not sure about installing one on an 01.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,352 PostsLatest Activity: Jan 20, 2025
