illpanteraa's avatar
illpanteraa
diy wiring
Hi everyone. New to RVing just purchased me first rv 76 Glendale. I'm planning on some minor upgrades in the electrical system the coach has the power convertor. I will be adding generator inverter and 4 12 volt 52 amp deep cycle scooter batteries. The converters 12 volt system is wired to run off the alt.but us missing the aux batt I kinda need some help figuring out a wiring solution I'm planning to run the gene to run the 110 side when boon docking and charge the Batts when it's running and keep charging the Batts off the alt when running the coach when the gene is off seems a little complicated I'm had at wiring and plumbing and stuff but don't want blow my converter bu adding 12 volt sources from different charging sources help would be greatly appreciated
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,397 PostsLatest Activity: Dec 04, 2025
