TURNKEY's avatar
TURNKEY
Fridge Vent Fan Questions
Two questions, and I would appreciate the wisdom of the crowd:
1-I want to add vent fans to my small 5ver's fridge 'chimney' to improve cooling. I intend to use 2-3 computer fans. I assume it would be better to mount them at the very top of the chimney,(just under the bug screen that caps the chimney below the top roof cap) so as to 'pull' the air up, rather than on the inside of the bottom vent or below the cooling unit and try to "push the air up.
This is based on my belief that the heat generated by the fridge will naturally rise and will build up from the top down in the chimney. Just like an attic fan will cool your house better than trying to push air into your basement with a fan.
2-I don't want the fans to run if it isn't necessary. (We are off grid 95% via solar and I HATE all generators. Even mine.) Therefore I intend on installing a thermo switch to control at what temperature the fans will kick off and on. What temperature should it be rated? And where should it be placed?Norcold 6.3 foot reefer.
Thanks for your help.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,358 PostsLatest Activity: Mar 25, 2025
