marininn's avatar
marininn
Generator Lock
I am searching for ways others have secured their generator, specifically when mounted to a receiver hitch tray.
I made my tray, but have only come up with a slightly complicated way to lock it on, one that is hard for thieves to get to…
Currently my idea is a 2 inch flat metal stock bent over and around the generator and continue under. A hole in each end for a solid pipe to run through and padlock that to tray.
I am afraid a chain is too common a thing for thieves, so looking for unconventional.
I have a Ryobi 2200 inverter and there is nothing to loop through with a chain. The handle can be easily unscrewed so do not count.
Generator is on front receiver hitch, and a long cord ran to camper. Noise free inside camper yet still attached for driving… I am not always with vehicle, and sometimes parked in cities.
  • the harbor freight one I saw looked to me to be much more massive than this one.
    bumpy
  • mobeewan wrote:
    You might contact
    lowprolockdown.com and see if they might be working on a design for Ryobi generators. So far they have designs for 3 different Honda's, a Yamaha and a Champion. Basically they use a mounting plate that uses the holes for the foot pads bolts. The plate fits into a frame and uses a round Master padlock that fits into a shielded recess to lock down the generator.
    This is the route I went. I adapted a Predator 3500 inverter generator to a Honda 3000 LowPro Lockdown plate using 1" square tubing and 1" rubber vibration isolators. I used carriage bolts (rounded head) for all attachments which bolt through the tray the plate locks on to. There is no way to loosen the bolts without removing the tray.
    I mounted the generator/tray combo to the rear of my TT directly on the bumper using Mount and Lock tray brackets. Yes the bumper has been reinforced with 1 1/2" square tubing bolted to the frame so the mounting is quite durable and stable.
  • Fasten the generator to the mounting frame with U-bolts. File off the points on one facet of the hex nut used to tighten the u-bolts. Make sure you have the correct size 6 point socket to loosen the U-bolts, should it be necessary. Thieves are masters of opportunity so will leave if a twelve point socket is used or if getting access to the connectors is a problem. Make it a problem.
  • on my Honda 2000, I have 1/8" straps welded to a bottom tray. They come up on the sides and stop about the height of the handle.
    There's a hole in the center of the strap - and a pipe runs through the straps with a padlock on one end and a large metal ring on the other.
    It's still strapped to the metal tray.
  • A bike chain is certainly worth consideration but as mentioned these can be cut often easily. Torklift makes anti theft brackets, Anyone with a welder should be able to make something suitable.
  • If the greater has rubber feet like mine did you can take them off and use the screw holes to mount the generator to you tray. Not sure what yours looks like but you could give it a try.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,351 PostsLatest Activity: Jan 18, 2025
