DeansDad's avatar
DeansDad
Hunter thermostsat conversion problem
I decided to do the Hunter 42999B conversion on my TT as the Duo-Therm thermostat was like all the others.
I have a Dometic Duo-Therm 13,500 roof air, and I THINK an Attwood furnace (if need be I can remove cover to check).
Here's what I did:
red wire was on Duo-Therm +7.5 terminal, I didn't use it
yellow wire was on Duo-Therm cool terminal, to Y on Hunter
white wire was on Duo-Therm furnace terminal, to W on Hunter
blue wire was on Duo-Therm hi fan terminal, temp not used
orange wire was on Duo-Therm fan terminal, to G on Hunter
green wire was on Duo-Therm gnd terminal, to RC on Hunter
I left the jumper from RC to RW in the Hunter
Also, the small switch is set for HG
I have the furnace working properly, but when trying A/C all I get is the compressor running, no blower fan. Also, there is no fan when the manual fan position is switched on, either.
This seems so simple a conversion, can't believe it's not working right.
