- mike-sExplorer IIWhatever you do, the house/chassis charging will likely need to be separately adjustable. Deep cycle batteries almost always use different charging profiles than starting batteries. Note that the linked Echo Charge page says "both battery banks must be the same DC voltage and battery type."
- MrWizardModeratori know there are chargers that charge (2) banks seperately
'true charge' comes to mind
but i am unaware of any 'inverter-charge combos' design for (2) banks - Sam_SpadeExplorer
theoldwizard1 wrote:
The "low cost solution" would be hook up the long wires to the vehicle battery and run them back to a Schumacher charger plugged into an AC outlet off of the inverter.
I was going to suggest that too BUT.....people want what they WANT and don't want to hear about simple alternatives once their mind is made up......sometimes.
For instance, mine has a 110 AC outlet up front near the engine compartment. If I needed to do this, I would mount a tender-type small charger behind the dash or in the engine compartment and run the battery wires the short distance to the battery......and leave it plugged into AC all the time. Whenever the 110 supply is hot from any source, the battery maintainer would be active. - theoldwizard1Explorer IIThe "low cost solution" would be hook up the long wires to the vehicle battery and run them back to a Schumacher charger plugged into an AC outlet off of the inverter. Make sure to use adequate size wire, but you probably really just want a trickle charge anyway.
- GordonThreeExplorerMagnum Energy should have what you need. Check out the ME-SBC Smart Battery Combiner
Use it with a Magnum Inverter+Charger, like the 3000 watt 12v hybrid model. - You want to just have the inverter charging the primary house battery. Any inverter/charger will do this.
Add a battery combiner to charge the chassis battery. For continuous power probably a 5 amp Trik-L-Start is fine to keep the chassis battery topped up. If you need heavy charging on the chassis battery you need a bi-directional relay that senses charging voltage, aka BIRD. - DrewEExplorer IIIA good bit less expensive than the Echo~charge (and quite well regarded) are the LSL Trik-L-Start and higher current Amp-L-Start devices that do the same basic thing and operate in a very similar manner.
- Sam_SpadeExplorer
roostonu wrote:
I answered my own question though with a little more research.
And maybe you would like to share it with the rest of us ??
My RV is set up to do that off of a single "standard" converter/charger. I think it does it via a rather simple "battery controller" and a solenoid. It charges both going down the road too.
It appears that the ONLY time the two "banks" are isolated is when the engine is OFF and there is no shore power (and no generator). - roostonuExplorer
lawrosa wrote:
roostonu wrote:
I'm looking for an inverter/charger that can charge the starter and house battery banks independently. Is there such a thing or a way to make it happen from a single charge output? Thanks.
Not an inverter but a two bank 10 amp waterproof outdoor charger...
https://no.co/gen2
I know there are many ways to charge the two banks, but I'm looking for inverter/chargers specifically.
I answered my own question though with a little more research. - lawrosaExplorer
https://no.co/gen2
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 30, 2026
