profdant139's avatar
profdant139
Explorer III
Jan 29, 2018
"Rabbit ear" wing nuts for battery posts: odd, but it works
The wing nuts on my battery posts are kind of tedious - they don't spin well, so it takes too long to connect and disconnect the batteries, especially in cold or wet weather, since my batteries are mounted on the tongue of my trailer. (This little project is probably not worth the effort if you rarely disconnect your batteries.)
So, I tried an experiment, and it worked! Using my drill press, I drilled 1/8 inch holes in the "wings." I then cut two 1 inch by 1/2 inch pieces of thin steel for the "ears." (Yes, the steel will eventually rust - I don't care. It's just camping, not a beauty contest.)
I then drilled matching holes in those two small pieces of steel. I used a simple "pop rivet" tool to join the extensions to the wings. I pounded down both sides of the rivets on an anvil and then used a flat file to smooth off the rough edges and to shape the "rabbit ears."
When I threaded the wing nut onto the battery post, the "ears" meant that I could flick the wing nut with a finger, and it would spin onto the post. The length of the "ears" provides a little more leverage, and the weight of the "ears" provides a little more momentum.
Note that the ears are not quite vertical -- I wanted to make sure that they did not interfere with the threaded battery post. And note that they are not horizontal -- otherwise, they would have come too close to the main battery terminals.
Here is a "before and after" photo - again, not pretty, but it works:
Click For Full-Size Image.
    Hmmmm, my current battery which I'm replacing in the spring has wing nuts and truthfully I can't say I've ever considered them to be an issue. However, if for you they are wouldn't it just be simpler to use nuts and snug 'em up with a socket wrench? :h
  • Almot's avatar
    Almot
    Explorer III
    Profdant, you're right - not important if batteries are not disconnected often (and they shouldn't, IMO).
    Not much can fall part there, other than the modified part - pop rivet.
    I use only stainless hardware on batteries, so drilling and cutting would be difficult. Something to consider for those close to sea.
  • :)I think you have RABWITARTTD Syndrome (retired and bored with increased time and reduced things to do). I do not consider it a debilitating condition and have spent many an hour, ok sometimes days, developing, building, modifying, rearranging things that are best left alone. ;)
    I generally find I have broken, lost, or changed something irreplaceable at some point in my "improvement".
    Now if it was me I would have built a fork like attachment for my drill and used that to spin the nuts off.
    Cleaning the threads of the bolt being the last thing I would try.
    Neat job and a satisfying out come. :)
  • I should also add that as the photo shows, I mounted the ears on opposite sides of the original wings, so that the whole assembly would be symmetrical (and would spin more evenly as a result).
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
