jspringator's avatar
jspringator
Replaced roof molding screws
I replaced all the screws in the molding holding down the rubber roof with stainless steel screws dipped in 3M5200. That is a lot of screws!
Do I need to do anything else? Run a bead of sealant at the top of the molding? Cover the entire molding with Eternabond? I can't see either one of these would be an improvement on the crews heavily dipped in 3M5200
About 3/4 of my screws had rusted threads. On mine, a clog in the gutters caused water to rise into the screw area. I can't see that the plastic screw cover does anything but make the moisture hang around longer. My rig just turned 10. I wish I had done this 9 years ago.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,401 PostsLatest Activity: Jan 01, 2026
