Jackutah's avatar
Jackutah
Switching out 110/120 volt wall outlet in RV
I have a couple 110 outlets in my RV .. 1993 itasca ... That I get good voltage with meter when wiggle around in slots... But when something plugged in ..nothing runs... So I figure the contacts are worn inside so contact is not proper...... So I was going to buy replacement outlets from my local Home Depot and switch them out...
Is there a problem with this.. Do I need a special type outlet or are they just the same as a home outlet
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,408 PostsLatest Activity: May 09, 2026
