- PalindatExplorerI have a 2010 F150 with max tow and a 5.5 ft box. My trailer is a Security W26SLQRK with a 10 inch King Pin extension. The hitch is a Curt A16 Slider. When loaded to go, my truck axle weights are just about at max. I have been towing this trailer for a couple of years now through the Canadian Rockies and the windy prairies. I've had a few pull behinds over the past 20 years and this setup is by far the best I've ever had. I have also never used the slider. I have E rated tires, 3.73 gears, 6 speed trany and 5.4 l engine.
- mileshuffExplorer
philh wrote:
full gas is in the cars base curb weight
True but UVW does not. Depends on what figures are used. - philhExplorer III
mileshuff wrote:
4 passengers at 150 lbf each is 600. 30 gallons of gas is 180. Add cargo and you're easily topping 900. If it's just 2 people then sure, it's less! As for payload that is split between both axles. Whats the max pin rating for the bed?
full gas is in the cars base curb weight - mileshuffExplorer
wing_zealot wrote:
which for some reason you seem all bent out of shape about.
Asking a question is bent out of shape? Sheesh!! Tow whatever you want and have fun!! - wing_zealotExplorerThe RAWR is on the sticker of which I provided a picture of way back on page 1. There's enough information on that sticker that you could determine the piston diameter of the left front caliper if you wanted to (2.13 inches, each, of two). The fact remains, "I can easily tow a 8000 lbs fifth wheel with my half ton", which for some reason you seem all bent out of shape about. (Most people would just read the sticker and say, oh!, ok, maybe it could)
Get over it, the old saw of a "half ton can't _____" is now out the window. Ratings have changed over time just like they have for 3/4 ton and 1 ton.
A half ton is fully capable of towing up to 100% of its ratings as long as it doesn't exceed any rating - regardless of what the badge on the side says. Its time to start talking about ratings, not what the badge on the side says. - mooky_stinksExplorer
mileshuff wrote:
wing_zealot wrote:
How is the Rating higher? - you burned up payload on that diesel engine. The curb weight of my vehicle is substantially less then yours. Even the gas version of your vehicle gives you several hundred lbs more payload.
Curb weight is less but the axles, diff, springs, frame are puny in comparison. All that aside, I prefer live axles over independent suspension when towing. Handles far better but that's just me. As for payload, again, that is typically split between axles. What is the rating for the rear axle alone?
My truck is very similar to wing zealot’s and mine has a RAWR of 4800lbs and a scaled weight of 2560lb on the rear axle with me(230lbs) and a slider hitch and a full 36 gallon fuel tank. So that leaves 2240 available on the rear axle. BUT at the full rawr of 4800 and the front axle weight of 3300. It would put me over my GVWR of 7850. So to be within the ratings I could still carry 2000lbs of pin weight, be at my GVWR and under my RAWR. - mileshuffExplorer
Curb weight is less but the axles, diff, springs, frame are puny in comparison. All that aside, I prefer live axles over independent suspension when towing. Handles far better but that's just me. As for payload, again, that is typically split between axles. What is the rating for the rear axle alone? - MFLNomad II
mileshuff wrote:
How are the newer 1/2 ton trucks rated higher than my 2007 3/4 diesel? My max pin weight rating is right near 2100 lb. I have looked at the springs and diffs, axles etc on newer trucks and they are no where near as beefy as mine. So how the higher ratings?
Have you weighed your rear axle separately, to know how much pin wt can be added? Should be a lot more than 2100 lbs. I'm thinking you have around 3K lbs available, before going over your RAWR.
Jerry - wing_zealotExplorer
mooky stinks wrote:
Exactly, for some reason they think I need to add 900 lbs of payload for me and my wife to go camping.
It’s funny how everyone talks weights and ratings and then you give them and they move the goal line. It just goes back to the outdated “a 1/2 ton can’t tow that”. - mooky_stinksExplorerIt’s funny how everyone talks weights and ratings and then you give them and they move the goal line. It just goes back to the outdated “a 1/2 ton can’t tow that”.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
