Steakman
May 19, 2014Explorer
2011 Coachmen Chaparral 275 RlS - Questions
Good day all.
I am looking for a copy of the original Coachmen brochure for this rig.
2nd: there 3 blue water lines found underneath door/awning side right by the axles. 2 of them are open and directly beside each other, the third has a white plastic male threading on it (and found an accompanying Cap in the HW heater outer compartment).
I am assuming 1, 2 or all three are vents of some sort.?
If so, which is the Fresh water overflow? And what are the others for?
What is the Cap/threaded tubes' purpose.?
I'm asking as there does not seem to be a reliable method for knowing when the fresh water tank is full - I also dont know if the threaded line needs to be capped or uncapped whwn filling up w/said Fresh H2O.
This is my first 5th (lovin it), and first w/TV. We normally watch natures "TV" (the camp fire), but on those rainy nights, nice ta have the "tube".
Last Question:
Will the 12V receptacle to the right of the DVD player work using an inverter to power the TV (can it handle the draw?). If so, what size of inverter would be required.?
Note, I'm running 160W solar and dual-brand new 6V batts.
Thanx in advanz for your replies!
Much appreciated.
Stk
Last Question:
Much appreciated.
Stk
