RetiredSquid
Oct 08, 2015Explorer
Anderson Ultimate Hitch WARNING ***WARNING
Email between me and Anderson Customer Service:
Jim,
Thank you for contacting us in regards to our Ultimate Connection Hitch and due to some flex in the bed of the truck we have changed the torque sequence on the base of the hitch to ensure it is snug when towing.
Place base over gooseneck ball and pin to the gooseneck ball
Tighten upper bolt to 50 ft.lbs of torque
Lower Trailer onto pyramid base (prior to tightening the two lower set bolts)
Re-torque the top bolt to 50 ft.lbs in case any flex of the base or bed came into play.
Tighten the lower two set bolts on the coupler tube to 40 ft. lbs.
Thanks,
Dave.
On 2015-10-07 13:36, Jim Cummings wrote:
Recentlly I read that Anderson revised the torque sequence on the
untimate hitch? Same as before but torque top bolt again after
connecting trailor?
True?
Jim Cummings
Jim,
Thanks,
Dave.
connecting trailor?
True?
Jim Cummings
