Izzy211 wrote:
Recently purchased a new Starcraft 5er. Upon inspection all break pads are shot. Pads peeled off of shoes. Upon farther investigation found axles rated at 4400 pounds each. GVWR of 5 er is 10,500 pounds. Something seems off. I know pin weight carries more load however, I am a little nervous at axle rating. Any help would be appreciated.
Axles are "sufficient", though I'd like 5k or 5.2k, personally. If this is under warranty, then the brakes should be re-done by the dealer. Sumpin' ain't right, for sure. Double-check that the tires aren't flat-spotted anywhere. I'd almost suspect that the brake controller was set too high or the brakes were =way= out of adjustment at the factory. Also check for any signs of over-heating on the drums. Any issues there, the drums need to be replaced, too.
Lyle
