rjsurfer's avatar
rjsurfer
Better to lower hitch or raise pin box?
I just installed an EasyFlex equalizer and noticed I lost an inch or so of height, it was a tad lower in the rear before the install so this extra inch is a bit too much.
I can either raise the pin box or lower the hitch.
What do recommend?
What are their advantages and disadvantages of each method?
And of course what's the easiest?, I'm thinking lowering the hitch would be the easiest, let gravity help me out.
Thanks
Ron W.
  • Personally, I'd look for a way to raise the FW. 6.5" of bed clearance is, IMO, pushing the margin of safety. I know I tow a touch nose-high and have right at 8" clearance; I've used all but about 1/4" of it a couple times...but that's because of where I like to camp.
    Lyle
  • Raise the pin box or lower the hitch should give you the same results. Raise the pin will lower the front. Lower the hitch will do the same thing. What makes the difference other than the amount of work? I would lower the hitch. It is a lot less work and easier that the other. Good Luck and Happy Camping.
  • I would probably raise pin box. Lowering hitch will put pin box lower in the bed and reduce clearence if you pack items around hitch?
  • On my setup (with a extended pin box and short bed) if I was to raise the pin box that would shorten the distance from the front of the camper to the truck cab. That would increase the risk of hitting the truck in a tight turn.
  • Old-Biscuit wrote:
    Installing that equalizer caused your trailer to sit lower so you are now more nose high than before.......
    Do you have enough bedrail clearance to lower nose of trailer?
    Lowering the hitch will be easiest.....raising pin box is heavy/awkward and requires lifting it up into place.
    With a helping hand......either
    But do you have the bedrail clearance?????
    I'm at 6 1/2 " now so I'm thinking I'm good for at least an 1 1/2" lowering without going below 5".
    Thanks
    Ron W
  • Installing that equalizer caused your trailer to sit lower so you are now more nose high than before.......
  • To gain clearance you lower the Pin Box, or Raise the Hitch. Are you wanting more bed clearance? I am sure that is what you are asking about, if so either way works. If you have an extended pin box raising the hitch will help with inside bed rail, and back of pin box problems. If you have a cover on your truck watch about raising your hitch so much it hits the cover.
