rhagfo
Mar 13, 2016Explorer III
cant_remember_ID wrote:
The rear wall is usually a different structure than the side walls, but I think further in investigation is needed. It could be just the stickers that are peeling up, or it could go deeper.
The rear wall can be replaced relatively easily, but if it is water damage, I would be concerned with they the water did to the frame. If there is wood structure, it may have some rot now.
Rear wall are many times plastic sheet over plywood, many times only attached at the edges.
Worth a deeper look, don't blow off a good rig, until you are sure.
About Fifth Wheel Group
