ret-miner
Sep 23, 2015Explorer
Changing Tires
Has anybody ever used a tire changing block that they sell that you drive one wheel up on it to lift the other tandem wheel to be able to change it
Arcamper wrote:Tin Pusher wrote:
Arcamper, question for you: After you have blown a tire on one of your two axles, how much weight is on the remaning tire?
If your equalizer works right and there is enough suspension travel the same amount there was to start with. If the tire that blows goes flat and the suspension will not let that tire drop then the full weight of that side of the trailer shifts to the good tire.
