Timay wrote:
I use and recommend the Demco superglide hitchhiker, as seen here:
http://hijacker.com/rv-towing-products/hijacker/autoslide/18k-under-bed-mount-ford-prep-package - cut and paste in your browser.
watch the video.
Tim
Thanks for this lighter, more affordable alternative! I see PPL has the MorRyde adapter plate for it as well.
Edit: I saw Demco had said redesigned with lower weight, but am seeing shipping weights of 321 lbs for the 21K and 289 lbs for the 18K. No installing without a hoist then.
Update: I found a site that lists the Demco 18K at 220 lbs which I think is just a few pounds lighter than the 18K PullRite.
Another update: I found the 18K Pullrite #1300 (Ford puck) at around 200 lbs so forget what I said about lighter. Demco must have meant lighter on your wallet! The Demco is over $200 less.
