- jdogExplorerWhen mine leaked, I found out the fittings were loose, was not leaking from the fluid tank as it appeared to be.
- GoostoffExplorerI have this problem as well. Trying to limp it along till the season is over. Then I will get time to fix it properly. Sure is making a mess on the bottom of the trailer though.
- JohnG3Explorer IIMy sister had the same leak with her trailer. Ordered a new fluid tank with o-ring and replaced both.
Only reservations I have using any silicone sealer is the next time it happens you have to remove all the silicone in addition to replacing the o-ring and without using silicone you can fill and use as soon as you're finished. - Rod_WiseExplorerI just fixed the same problem on my fiver. Just do a search on the RV message boards for the details. Basically remove tank and clean it out good; check o-ring and replace if needed (my looked good -- so reused it); put a bead of Permatex RTV silicone around the oring and around inside seal area of the tank and put back together. IMPORTANT: let set at least 36 hrs before filling with fluid. Good Luck
- Old-BiscuitExplorer IIIProbably the O-ring between reservoir and pump housing.
- 1492ModeratorMoved from Forum Technical Support
About Fifth Wheel Group
19,007 PostsLatest Activity: Feb 28, 2025
